What should I do? Denon AVC-A1SE or 3801?
Discussion in 'AV Receivers & Amplifiers' started by Jim Robson, Feb 8, 2001.
Tags:
  1. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
    I was just wondering if I should replace my Sony STR-DB 930 with a Denon AVC-A1SE or save a small fortune and buy the Denon 3801? Would I regret NOT having bought the AVC-A1SE for evermore? I already have the new rear centre surrounds in place ready for whichever unit I happen to pick. Yes I do realise that this question is like asking if I should choose a new Fiesta or a BMW M5!
    Regards
    Jim [​IMG]
    [This message has been edited by Jim Robson (edited 08-02-2001).]
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Of course you will regret not buying the AVC A1SE if you don't buy it, it's just one of those things!
    Do what your wallet tells you, and your ears!
    rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Jim, Go for the A1SE, you know you want to, if you buy the 3801 you will always have that nagging doubt and you'll only end up upgrading again in a years time.
    I've just boxed up my demo unit and I pick mine up tomorrow. [​IMG]
    BTW In my view the price difference is justified.
  4. colemric
    colemric
    Go for it - don't forget that you get a wonderful remote control "free" - that must be worth a grand or two surely???
    "Build it and they will come"
  5. Spaceman
    Spaceman
    If you can affort the A1SE, then you should also give the Yamaha RX-V3000 (AX-2) a try. This receiver looks beautifully and also sounds wonderfull. It has DTS ES (matrix) and DD EX, 6x100W RMS and 2x25W (front special effect speakers).
    I was going for a Denon 3801, but after seeing and hearing the Yammy in action, I'll wait a few extra months to get the additional money.
  6. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Well, so far it looks like I've been 'forced' to go for the AVC-A1SE [​IMG] and that's good!! All I have to do now is find out where to buy one at the best price. They can certainly be had for less than £2,000 via genuine Denon Gold dealers with the 2-year warranty; there's no point in buying an import especially as there's word of future software upgrades for Dolby Pro-Logic 2 etc which might have to be performed by a genuine dealer. [​IMG]
    Spaceman, I'd have thought a Yamaha AX-1 would have been the more logical competitor to the AVC-A1SE or were you comparing it more with the Denon 3801? The AX-2 (and AX-1)only has 'matrix' ES and EX I believe. If I shell out all that loot I want all the bells and whistles! [​IMG]
    Thanks for your votes guys and I'd still be interested to hear more points of view. [​IMG]
    Regards
    Jim [​IMG]
    PS The new speaker cable and connectors for the centre rears arrived today so all that's needed for THX-EX and DTS-ES Discrete is the new amp! My fingers are itching to swipe the plastic!! [​IMG]
    Sorry about all the smilies but I think they are soooo cute! [​IMG]
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Fine choice sir, remember to bend the knees. [​IMG]
  8. Spaceman
    Spaceman
    Jim,
    Sorry, I was mixing the A1SE with the A10SE.
    The Yamaha AX-2 is more like between the Denon 3801 and A10SE.
