Fansari
Established Member
Hello All,
I need some help please with a decision. I currently have a yamaha rxv-581 and monitor audio mass 10 system.
I have been thinking to upgrade the sub to a svs-pb3000. I can't decide if I should upgrade the fronts and the centre as well?
I have been to richer sounds for a demo and heard the monitor audio silver 200's and matching centre speaker and like the sound. I have just come across the monitor audio monitor 300 which are not that different on the specs but price is half of the silver 200 range. If I buy the fronts and centre I will need to upgrade the amp as well to onkyo txnr696.
What do you guys suggest, should I upgrade the sub and see how it all blends in and then buy the rest or buy the whole lot?
As usual tight on budget .
Thanks in advance
Thanks in advance
