What should I buy now?
Discussion in 'LCD & LED LCD TVs Forum' started by warhorse, Jul 13, 2005.
Tags:
  1. warhorse
    warhorse
    Apr 23, 2005
    15
    I've owned a Video7 V7LTV26C 26" lcd for a couple of months now but I have persuaded Ebuyer to give me a full refund as I have had nothing but trouble with it, it went to Germany for repair as it developed the infamous 'tearing' effect which took nearly 6 weeks and then 2 days after I had it back the screen started tearing again and also developed another fault where the screen would go blank after a couple of minutes of use. I must say that Ebuyer have been great but I would have to advise anybody that they do not buy a Video7 V7LTV26C 26" as in my experience it is unfortunately a piece of junk.
    So, what should I buy now then? I want a 26 inch lcd that will be compatible with the upcoming Sky HD transmissions, it must also have a dvi input so I can plug in my Mac Mini. I would rather have a 16:9 but will settle for a 15:9 if the price is right. I'm looking to pay less than £700 including VAT.
    What do you lot recommend?
    Thanks,
    Warhorse
  2. demonofthefall
    demonofthefall
    Samsung LE26R41B / LE26R51B. Seems to get rave reviews from everyone here and it can be found for £610-650 on froogle and pricewatch. I'm ordering one this evening :devil:
  3. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    Im gonna get one of them as well...probably from web electircal or empire direct....thanks for everyones help on here
  4. warhorse
    warhorse
    Apr 23, 2005
    15
    It looks really nice but from what I can see there is no dvi input so no use for my mac mini.
    Cheers,
    Warhorse
  5. warhorse
    warhorse
    Apr 23, 2005
    15
    In the end I have decided to buy a Toshiba Stasia 27WL55 from Pixmania, from what I can see the price is up and down more often than Paris Hiltons undies, it cost me £523 but has been down to about £470 in the recent past.
    It isn't compatable with the upcoming Sky HD transmissions but that's not a major problem for me really.
    I will post a review on the set after a couple of weeks of use.
    Cheers,
    Warhorse
  6. benwong
    benwong
    I was under the impression that this samsung was HD ready meaning at least a DVI or HDMI port.
    Ben
  7. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    The Samsung has HDMI.
    Finding the 26" is no problem, but finding one in stock is another matter... :censored:
  8. benwong
    benwong
    Exactly.. all you'd need then is a DVI to HDMI cable.. :smashin:
    I'd say the Samsung would be the better choice, instead of faffing around with a TV from France (it takes 2 weeks for pixmania to issue a refund, or 4 weeks to replace the set).
    Ben
