what shall i do...???
Discussion in 'Subwoofers' started by celestion, Aug 31, 2004.
  1. celestion
    celestion
    i have a celestion csw mk2 subwoofer '97 and its quiet a good sub but...
    on certain bass notes wen i turn it up it makes a hurendeous rattle noise!!
    any one had the same problem????
    i think maybe the driver is hitting the wood on the inside cabinet.
    is it worth opening it up and having a look??
    also what inch is this subwoofer...???
    celestion_no1
  2. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +669
    While you may be right if something has actually worked loose. :rolleyes:
    It would probably rattle all the time if that was the case. :thumbsdow
    It is more likely that you are exceeding the ability of the drive-unit to follow the signal. The cone is hitting the end stops. :eek:
    It's called "Bottoming out" in subwoofer circles. :oops:
    Nothing to do with mooning though. :blush:
    Don't turn your sub up so high. Or you'll quickly wreck it. :nono:
    You may want to consider a more powerful subwoofer if you really like bass. :smashin:
    There may be other opinions regarding your sub's symptoms...? :cool:
    Nimby
