What screen material should I get?
Discussion in 'Projectors, Screens & Video Processors' started by MartinH32, Feb 13, 2018.
Tags:
  1. MartinH32
    MartinH32
    May 6, 2005
    2,513
    7
    5
    Selby
    +826
    I've been given the go ahead for a movie room. I'm designing it as I like, so it will be light controlled (dark walls and ceiling) and I'm going to be putting in a fixed screen. I'm after suggestions on what I should get for a screen material? I'm more than happy to to fit and build a frame myself.
  2. 494930
    494930
    Dec 15, 2016
    1,484
    116
    Lisburn
    +1,343
    Is this to be a dedicated room? If so Filmex material for an acoustic screen and Devore everywhere else.
  3. MartinH32
    MartinH32
    May 6, 2005
    2,513
    7
    5
    Selby
    +826
    Yes it's dedicated. I've everything sorted apart from the screen - doesn't need to be acoustic though, speakers are under and either side.
  4. mbmapit
    mbmapit
    Feb 15, 2005
    1,905
    Stansted
    +435
    Ear height? If not, would putting them behind the screen help them get to ear height?
  5. MartinH32
    MartinH32
    May 6, 2005
    2,513
    7
    5
    Selby
    +826
    Yes ear height. Like mentioned I don't need anything acoustically transparent
  6. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,770
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +718
    If you are going to place the speakers behind the screen then a transparent screen is a must, Gain wise, you'll ideally be looking at a gain from 1 - 1.4 Gain.
    We have a number of fixed screens which are transparent
    Another one I would look at is whether you wish to add a 2.35:1 screen and use a projector with memory zoom. This will help you create a real cinema experience compared to a standard 16/9 screen. You'll have to work out your distances though, the smallest zoom will have to fit the viewable height of the screen 2.35:1 and the viewable width for the longest zoom. Lens shift is also critical enabling you to alter the lens height for differing screen heights.
    To check out a few 2.35:1 screens view our link below
    Projection Screens - AudioVisual Online - UK Home Cinema and Hifi Specialists
  7. MartinH32
    MartinH32
    May 6, 2005
    2,513
    7
    5
    Selby
    +826
    Thanks Shane, I'm thinking of going down the line of a 2:35 to 1 ratio screen. My 9300 does have lens memory on it so it certainly is doable with CIH if I'm happy to have black bars at the left and right of the screen on 16:9 content (of which I don't have that much). I'm aiming to get it mounted this weekend so I can see size etc. I've done it on paper but until I'm in a seating position and see something in reality!!! There is always the possibility moving forwards of adding some form automated side masking triggered by the remote control when I change the lens position.
    As said before though, I don't need anything acoustically transparent
  8. ShanePJ
    ShanePJ
    Jun 20, 2006
    2,770
    +718
    The Epson will be fine for CIH. Every time I’ve ever seen someone viewing a 2.35:1 screen showing a 16/9 movie, the height is always the winner, then when a movie with 2.35:1 is played and the image grows in width, it’s a fantastic experience and one that makes you feel your at the pictures
    Just remember about the subtitles when view 2.35:1, some players let you move them, others do not
    Enjoy
  9. True Romance
    True Romance
    Feb 7, 2005
    6,980
    Wolverhampton
    +3,036
    Can still use Flimex. It's cheap, easy to work with and gives great results.
  10. mb3195
    mb3195
    Dec 27, 2007
    1,890
    2
    116
    Peterborough
    +1,839
    PSM screens mate. ProWhite projector screen material - PSM Screens - Projector Screen Material UK
    I’ve tried loads, this is the best for the money, compares to much more expensive materials.
    The other one that gives great results is Harkness Screens. They are a commercial grade supplier, have used it in the past, again, very good.
    Check out my build thread for an idea on adjustable masking. If you’re building a diy screen is strongly recommend doing something similar.
    New outbuilding dedicated cinema room - finished
  11. MartinH32
    MartinH32
    May 6, 2005
    2,513
    7
    5
    Selby
    +826
    Thanks PSM seem to be the only screen supplier in the UK from what I can see
  12. mb3195
    mb3195
    Dec 27, 2007
    1,890
    2
    116
    Peterborough
    +1,839
    Harkness supply also
