What screen for pj?
Discussion in 'Projectors, Screens & Video Processors' started by Cool-hand, Oct 9, 2003.
  1. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    Hoping for some good advice here. What screens are you using for your HC PJ's?
    I've been looking at various models at AV-Sales and am not too sure what to go for, or which size even. It has to be electric and poss. RF remote controlled. I'm putting it in a room which is about 5m x 4m. Don't really wanna break the 1k mark but will if it gets me what i want.
    Options are :- (got to be electric too)!
    1. Draper Baronet 16:9 screen
    2. OWL Othello Electric Homevision 16:9
    3. NexNix Electric Tab Tensioned Cinema Screen
    4. OWL Frame Homevision 16:9 (is this a perm. fitted screen?)
    Are TAB tensioned screens far superior to non-tab?
    I've also been looking at the Ceiling ressessed Draper range but have no prices yet.
    And finally the pj will be a DLP type. Should i be too concerned about screen gain or is there a standard recommended level?
    Many thanks
    S.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    All was well untill you said DLP then I realised you had come in the wrong door.
    The Dapper Baronets are on very small rollers and tend to crease after a while
    The Owl are petty good
    Never heard of a NexNix sounds like a type of crisp.
    Have you considered a Vutec should come in at less than £1000 and would be better then any of the above.
  3. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    522
    North Cotswolds
    +3
    Thread moved into correct forum.
