What Scart cable?
Discussion in 'Cables & Switches' started by Mojo Jojo, Jun 14, 2002.
  1. Mojo Jojo
    Mojo Jojo
    I've just ordered my new widescreen TV and I would like to get some good quality SCART cables - providing I'll notice the difference. I've seen many articles on cables but some seem to contradict themselves and now I'm left more puzzled than when I began.
    I'm looking for cables to connect a DVD player direct to an RGB SCART and to connect a SKY Digibox direct to the other RGB SCART.
    I don't really want to spend a forture but if I'll notice an improved picture quality then I don't mind investing in quality cables.
    Any ideas/recommendations?
    Mojo
  2. Dunky
    Dunky
    Nov 15, 2001
    60
    Surrey
    Quality scart cables are a good investment. They should last considerably longer than the kit that they are plugged into!
    You can't go wrong with anything from Ixos or QED. Decent lead will cost £30-£50 depending on length and exact model. Some others on the forum may be able to suggest cheaper leads that still give a quality picture.
    Cheers.
    Duncan
  3. Squirrel God
    Squirrel God
    Ixos 126AV. My favourite and excellent build quality (will probably last a lifetime) ;)
