Quantcast
What SACD player
sticker
I'm in the market for a dedicated SACD player, I'm not going to pay silly money for the player so I'm really only up to around £900 max. Two players I have my eyes on are the Sony SCD-XA3000ES and the Sony SCD-XA333ES.
I've read somewhere, can't remember where, that some SACD players are really a fudge and that only certain ones play SACD as it was truley envisaged, something to do with the internal manipulation of DSD to PCM?
I know The Beekeeper has looked into SACD in the past (any comments would be most useful Nic ;) ) but what are peoples views of the quality of SACD palyers out there? I should point out that I'm only interested in the multi channel players, not the early 2 channel Sony's/Marantz.
As a final point what are the players at this price level like at straight forward 2 channel stereo CD replay like?
Regards
John
alexs2
Originally posted by sticker
Regards
John
I think your comments re DSD to PCM conversion apply to some of the cheaper universal players,and certainly not to the higher priced Sony players,but I'm sure Beekeeper will clarify that.
The more expensive Sony's are generally excellent players,from what little listening I've had,whilst I wait and see which format will win out in the end!
At the price level you're considering,the CD replay quality is actually pretty good,although not as good as a dedicated CD player at that price level(my opinion only).
As always,the best way to decide is to get a few home on demo and decide using your own system,and seeing if you can hear the differences first.
sticker
Cheers Alexs2,
Could you do me a favour please and explain what your Perpetual tech gear does, you have the P1a and the P3?
cheers
John
alexs2
Cheers Alexs2,
cheers
John
Certainly....I have both the P1A and P3A.....the latter is basically just a very good DAC,and with the possibility of further upgrading it via a better power supply,and higher spec internals(these are the Monolithic power supply and the Modwright upgrades respectively).
On it's own the P3A is a good DAC can certainly the equal of anything in the £1000 bracket,but in combination with the P1A it's in a different league altogether.
The P1A is a DSP based device which upsamples 16bit/44.1kHz CD to 24bit/96kHz resolution,but is different from most other simple upsamplers in using the Sharc DSP to interpolate data into the 16 to 24 bit gaps according to a proprietary algorithm which I wouldn't pretend to understand!
Whether or not you believe in this sort of thing(and I certainly am not impressed by simple upsampling)the results from this are very good indeed,and not just to my ears,but also those of many respected reviewers and customers.
It's nearly as good as SACD or DVD-A if properly setup and used with appropriate quality ancillaries,and easily as good as most midrange Wadias or Levinsons,at a fraction of the price...well worth a listen....a lot of the HiFi News reviews recently have compared the combination very favourably with MF,Krell,and other high end DACs.
Have a look at www.audioreview.com for a few customer reviews,and also www.av123.com for the manufacturers site.
There is a UK based importer but I can't remember the name for sure...I think it's www.connoiseuraudio.co.uk.
sticker
Thanks Alexs2 for that. Can you tell me how this works with both high-end CD players like a Meriain 508 and a simple DVD player like a Pioneer 656. Would the end results be similar or does the transport make a big difference in its own right? The reason I ask is that currently my main CD player is my Arcam FMJ DV27 but I also have a Marantz CD6000KI and was wonerding if I could source a decent DAC/upsampler and connect that to the SACD player I'm looking at and then change my DVD to a HTPC, I could rationalise my kit and probably save money into the bargin!!
Regards
John
Ed Selley
AVF Reviewer
It will be a struggle to find one for £900 but the Marantz SA17 is the best SACD player I've heard and it is at least as good as a CD6000KI for straight CD replay. It is (so far) the only standalone SACD player that made a strong case for itself that I have heard. Beautifully screwed together as well.
Ed
alexs2
Regards
John
OK....the transport does make a difference,but not as much as you might think,as both the P1A and P3A reclock,and the P1A is ideal for that purpose.
Transports aside,whilst both accept CD data,neither will accept or pass through any other format currently,so you would have to be careful not to try that!
If you were contemplating getting one or both of these,I would keep your best transport,and use it simply as that,running it direct into your AV processor from there....an alternative is to use the P1A to upsample/interpolate CD before feeding it into the processor's DACs if theyre good enough to make it worthwhile.
For a bit of comparison,the P1A/P3A is significantly better than just running the P1A into a Tag AV32R's DACs.
sticker
Thnaks guys for the info, much appreciated.
Tons, I think the Marantz is a bit outside my price range so that will probably have to fall by the wayside.
Regards
John
sticker
OK after a bit more research and demo's I've narrowed it down to
Sony SCD XA-777ES
Sony SCD XA-3000ES
Marantz DV8400
Only problem is I've yet to hear these back to back, has anyone heard them back to back?
Regards
John
Ed Selley
AVF Reviewer
The 8400 is a good SACD player and no mistake- it is our usual warhorse for multichannel music and is a good ambassador for the format.
However, have a look on the US Marantz website for the SA8260. A little bird tells me that the "SA8400" (due 3rd quarter 2004) owes more than a little to this machine ;).
sticker
Thanks for the pointer Tons :)
John
Spligsey
John.
The SCD-XA777ES is a class act SACD wise.
I've heard this a couple of times & it sounds top dollar.
Pretty nice on CD's too:)
Battleship build - i nearly purchased one of them a while ago, but couldn't, coz i was el-skinto.
I still think the best SACD player i've heard is the Marantz SA-1
May only be 2 channel - but what a ****ing player that is.
Adz
sticker
Hi Adz,
Thanks for the pointer, I think that I've found a 777 pretty cheap, still a bit more than I wanted to pay but I might have to just bite the biscuit. I did want to compare it to the 3000ES but so far no luck. I really want to hear them back to back if I can (learnt that lesson a couple of months ago :)).
Agree with you about the Marantz SA-1, I heard this about 6 months ago and I was astounded, trouble is the price.
Have you heard either the TEAC DV50 or the Linn Unidisk, outside my price range but interested in your opinion if you have heard them.
Regards
John
Spligsey
Morning John.
Haven't had the pleasure of hearing the Unidisk players or the TEAC either. I would've thought both would be top flight.
TEAC have great reputation in the HiFi world for building top quality transports with VRDS mechanisms which are used by Wadia & Levinson to name a few. Their Esoteric range looks fantastic :cool:
From what people have said about the Unidisk, then i'm confident that it will be of the highest quality.
Naturally, both designs would set you back a fair few quid.
By all accounts, the latest Sony SACD players are supposed to be excellent value. Their ES badged machines have superb build quality.
Adz
sticker
Thanks again Adz for you help, much appreciated
John
D
dubai2000
I am surprised the Philips 963SA isn't mentioned. Yes, it's a DVD player as well (and that's why I originally bought it), but I am completely surprised (understatement!) by its CD(!)/SACD playback. I suppose it will actually end up as my main digital source....a development not all expected.
Wolfram
NicolasB
I seem to recall that there are some issues with the Unidisk's bass management with SACD - namely, that there isn't any. But it was a long time ago that I heard that (assuming I didn't imagine it). :)
sticker
Ok I took the plunge and bought a Sony SCD-XA777ES, got it for a good price (I think). :clap:
Thanks to all for their advice and particularly Bee
John
alexs2
The Unidisk is reviewed in this month's HiFiNews,and seems to come out very well,albeit at quite a price....there is no comment re lack of bass management though.
Edgeyboy
Hi John
May I ask where you sourced a 777es from ? How much would I expect to pay ?
Many thanks
Tom.
sticker
Hi Tom,
I got it from Unbeatable, it was a customer return. When looking around the cheapest I could find them for was around £1,600 ( I got mine considerably cheaper than that though), but the average was £1,750. It seems that a lot of dealers don't have them in stock anymore, I don't know if that is because the 9000 has replaced it. If this is the case then you may be able to get a decent discount.
Regards
John
i would wait to you have enough for the sony scd-xa9000. ive seen it for £1000 in a store down south. it has no less than 18 d/a converts
dynamic turtle
Sticker,
I recently posted a thread about sacd players. I had initially budgeted £500 and was looking at the Sony 555ES, Marant SA8400 and Pio 868.
However, after hearing the Sony NS900V (dvd/sacd player from 2002), I thought it best to save myself the best part of £500 and ditch the 555ES.
Shameless plug over :D
Still, you've got your 777ES now. Am I jealous! Let us know how it sounds. Shame your running it through an (admittedly, very capable) AV amp. Do you not think it deserves a dedicated valve-based stereo rig instead?
DT
And if it doesn't sound any good, you could always bolt some tracks & a turret on it, and use it as a tank. That thing is monstrously well-built.
dynamic turtle
oh yeah, i feel *so* horny - just can't help myself :D
Trending threads
Latest News
Huawei launches Vision X65 OLED TV in China
  • By Andy Bassett
  • Published
Virgin Media adds more free Sky channels
  • By Andy Bassett
  • Published
Disney+ reaches 50 million subscribers globally
  • By Andy Bassett
  • Published
Samsung to end Smart View app support on older TVs
  • By Andy Bassett
  • Published
Leema Acoustics offers factory shipping for locked down customers
  • By Andy Bassett
  • Published
