what router can i get for cable for virgin
baker025p
all the ones i have looked online dont show the back of the router and most of them are showing me the adsl routers
ADSL is no good for cable virgin
Badger0-0
I would have thought Googling for "cable router" should bring up loads.
The one I'm using is the supplied Netgear WNR2000v2.
Why are you after one though?
If yours is duff or hasn't been changed for yonks, I'd phone Virgin.
baker025p
i have done that still cant see the back of the router
i am using Netgear WNR2000v2 and its going off line every 30mins for the last 4 days
i have phoned them and thery only just sending a new one out
i would like to have control over my router not for virgin to control over it
Badger0-0
Why do you need to see the back?
If it says "Cable router" that's what it will be and it'll work.
You've lost me there :confused:
What do you mean by Virgin controlling it?
Badger0-0
Have you tried typing 192.168.1.1 into your browser?
You should be able to set it up how you want then.
Badger0-0
192.168.0.1 for netgear
yes i have been in to my router and the connection part is locked
What do you mean it's locked :confused:
To access the settings on that router, WHICH ARE ALL THERE, see above.
(Unless I've totally lost the plot :suicide:)
You're not making yourself clear at all mate :(
Badger0-0
Ok, let's start again.
I apologise for the shouting, btw.
I should have just gone bold :suicide:
If you want to access the router settings you need to type 192.168.1.1, not 192.168.0.1
Does that solve your problem?
Fwiw, I had a similar problem with my previous Netgear 614 constantly losing connection.
I just got in touch with Virgin who sent me this 2000 and it sorted it.
baker025p
this is from my router and my Event Log is telling me Critical (3) DHCP FAILED - Requested Info not supported.
Connection
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 315000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Configuration File OK
Security Enabled BPI+
Downstream Channel
Lock Status Locked Modulation QAM256
Channel ID 99 Symbol Rate 6952000
Downstream Frequency 315000000 Hz Downstream Power 1.5 dBmV
SNR 39.3 dBmV
Upstream Channel
Lock Status Locked Modulation QAM16
Channel ID 5 Symbol Rate 5120 Ksym/sec
Upstream Frequency 45800000 Hz Upstream Power 48.2 dBmV
Primary Downstream Service Flow
Downstream(0)
SFID 7380
Max Traffic Rate 20480000 bps
Max Traffic Burst 10000 bytes
Mix Traffic Rate 0 bps
Primary Upstream Service Flow
Upstream(0)
SFID 8510
Max Traffic Rate 2080000 bps
Max Traffic Burst 8160 bytes
Max Concatenated Burst 8160 bytes
Scheduling Type Best Effort
that locked but i wont change Upstream Channel ID i cant do it
Badger0-0
So you're talking about your modem , as opposed to the router?
Unsubscribed.
nickp8
Virgin use two setups, the older was you had a seperate modem and a seperate router and they then switched to a combined modem and router.
You have the seperate modem and seperate router so you cant change the modem you can only use one supplied by them. You can change the router if you wish but your issue is not with the router. With a seperate modem and router each will have their own configuration page you need to go to via a web browser and log into to make any changes.
You say you want to change the upstream channel id, of course you cant do that! If your modem keeps dropping connection then you need to contact Virgin for support.
You can get support on the virgin community forum: Broadband - Help & Support Forum
Post on their support forum with the issues you are having.
