What RF adapter do i need to make this TV work
Discussion in 'General TV Discussions Forum' started by MoonpigMoonpig, Feb 18, 2014.
  1. MoonpigMoonpig
    MoonpigMoonpig
    Jan 4, 2010
    37
    11
    I have a really old retro TV Sentra CTV-5100 small 5 inch CRT TV.
    I am trying to hook my Atari up to it but the RF cable will not fit in the EXT ANT. I remember back in the 90s when i wanted to play Megadrive on this i had a little adapter.
    Can anybody link me the adpter i need to plug my RF cable into the EXT ANT?
  2. redaprilia
    redaprilia
    Feb 10, 2010
    932
    43
    +120
    The socket looks like a very old style car radio socket . Probable easier to make up a lead to a co-ax socket unless you can fine one on eBay ?
  3. MoonpigMoonpig
    MoonpigMoonpig
    Jan 4, 2010
    37
    11
  4. redaprilia
    redaprilia
    Feb 10, 2010
    932
    43
    +120
    That looks like the right plug , but you need a wire fitting to it and then a aerial socket to suit your Atari .
  5. MoonpigMoonpig
    MoonpigMoonpig
    Jan 4, 2010
    37
    11
    This is the cable that comes out of my Atari .
    Do you think i need a 2nd adapter? As i am sure in the early 90s i had just a 1 adapter that worked.
