What resolution
Discussion in 'Plasma TVs Forum' started by Andreas oakes, Apr 24, 2005.
  1. Andreas oakes
    Andreas oakes
    Dec 5, 2004
    228
    Aylesbury
    I have a DVDO Iscan HD connected to my PW7's PC input,
    Can anyone advise the best resolution to use, and the aspect ratio to set the Plasma to ie Just,16x9 etc.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    720p at 50Hz for Pal material and 60 for NTSC is ideal for the panny SD models:
    16:9 works well make sure you use a test pattern to correct the overscan (or book your friendly ISF calibrator to do it all for you, see www.homecinemaengineering.com for more info...............)
