What resolution will Blu-Ray discs output?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rob20, Aug 11, 2004.
  1. Rob20
    Rob20
    Jul 3, 2004
    3,210
    +737
    I believe dvd's have 500 lines of info, (no idea as to the number of pixel info per line). But what will the screen resolution output of blu-ray discs be? Just interested as Im wondering whether the 1366 by 768 of my Toshiba lcd will be sufficient.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,092
    Warwick
    +2,944
    When recording in High Res mode it will probably be 1080 x 768 although the video compression to be used has yet to be confirmed let alone the resolution.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Rob,
    I don't think anything less than 1920x1080p would be acceptable, although I'm sure you would then be able to select a lower output resolution your display could accept i.e 1366x768 LCDs or plasmas.
    Steve
  4. Rob20
    Rob20
    Jul 3, 2004
    3,210
    +737
    Is 1920 by 1080p, (at 60hz), the format for USA hi-def broadcasts?
  5. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Rob,
    No it's not, they use 1080i60, although 1080p30 is one of the many different ATSC resolutions allowed.
    Steve
