what resolution is best?...(help new member)
Discussion in 'Desktop & Laptop Computers Forum' started by carol harvey, May 22, 2001.
  1. carol harvey
    carol harvey
    I wonder if the forum can help? i have a geforce 2 64mb,dxr3 card and powerstrip also.Im planning to take the vga out of the graphics card into a projector which has a built in line doubler(but can handle 800 x 600 on the vga input).
    What resolution do i output the dvd at? 800 x 600 at 60hz?
  2. Blade
    Blade
    First try [email protected]
    Normally a VGA input will disable the onboard doubler effectively bypassing it.
    Once you have that working OK try a 72hz refresh rate.
    This should improve slow Pans across the screen.
  3. carol harvey
    carol harvey
    Thanks Blade,i`ll give that a try...
  4. carol harvey
    carol harvey
    Sorry Blade,one more question(i sound like Columbo!!)
    Do i set the resolution in powerstrip OR the graphics card?
  5. carol harvey
    carol harvey
    Hello...hello...earth to forum...any chance of an answer to my last question please?
  6. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    800x600 is a standard resolution so you can set it from the normal display settings. You can set the refresh rate (60/72 Hz) from the advanced display settings.
    Jeff
  7. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,685
    CJ - powerstrip is best of achieving resolutions and frequencies not usually available.
    If you can get 800x600 @72Hz in windows display properties, then you don't need powerstrip.
  8. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    unless you have a problem positioning 800x600 within the projectored image then you can use powerstip to help position and size it . can be handy to use powerstrip to set up all your resolutiones positioned and sized right then you don't have to mess with the settings on the projector as much
