What Resolution do you run your CRT at?
Discussion in 'Projectors, Screens & Video Processors' started by joust, Nov 5, 2003.
  1. joust
    joust
    Sep 4, 2002
    863
    28
    Basildon, Essex
    +49
    Hi All,
    Just a quick question, what CRT do you have and what resolution do you run it at?
    Joust
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    1424X784@47.952Hz (NTSC Film)
    1424x848@50Hz (PAL video & Film)
    1440x840@59.940Hz (NTSC video)
    Barco 1209s
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    You forgot to ask what size screen, makes a big difference.
    70" wide 16:9
    NECXG750 8"
    ntsc 720p 60
    pal 768p 50 (however I actually think that 720p 50 looks a bit better on my screen size, a little sharper, just set up a resolution with it tonight and it may stay there)
    can be arsed to play around with refresh rates myself, too lazy :)
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Why does screen size make a difference?
    The resoloution on the CRT tube face will be the same whatever size you use.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    I presume when somone asks about resolution they are trying to get rid of visable scan lines, and you know what I have never really sat down and thought resolution as such, but thinking about it now of course screen size shouldn't make a difference.
    However, if you had very small scan lines surley as you moved the projector back and increased the size the gaps would become slightly larger, as of course would the image lines. Obviously if the PJ was set absolutly spot on with all lines touching this would not be the case.
    Or am I missing somthing ?? :blush:
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,755
    Cheshire
    +108
    Everything should remain in proportion. If you can't see the scan lines on a 6ft screen then they shouldn't be visible on a 8ft.
    Regards
  7. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Jeff,
    What timings do you use with these frequencies?
    Rob.
  8. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    1024x576@ 50Hz, PAL all the way. Driven by HTPC
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Answer nearly all of them :laugh:
