Hi Just had a great 3 hr's reading in this forum. Some great threads. Can any one tell me the model number of the remote that comes with the nec 61mp1 or if any other remote's that will do the job, Pic's would be nice. What will i not be able to do with out the remote. cheers
Just found this: User Controls Direct Access: Power on/off, input selection, OSM access, (Control Lock Switch located on input panel) Remote Control: Power on/off, input select, volume, mute, wide, display, off-timer, OSM control, cursor, pointer, zoom, split screen, auto, select I have a sony STR 940 amp with a Sony RM LJ304 remote. Is there any way to down load the IR flash and IR it to the remote through the learn function? I Would like to just get a remote, if i could.
Looks like i can get into the OSM from the onboard button's and sort out: OSM Contrast, brightness, sharpness, color, tint, color temperature, picture mode, noise reduction, bass, treble, balance, vertical position, horizontal position, fine picture, picture adjust, auto picture, power management, RGB select, BNC select, HD select, OSM adjustment, gray level, PLE, reset, frequency, language, color system
Just found this. It's funny what you can find with the search button, i allways forget about that great little thing http://www.necvisualsystems.com/corpus/E/N/PX-61XM1A_MAN_2ed.pdf
Got a brand new remote from fleebay. PR 109. Sent from the usa $3.50 + $22 p&P. Great. Got me wall bracket from there aswell for £98 inc p&P.
