What receiver & what speakers please for newby
L
ladypickers
After advice from AV forum & HD went TCR this morning to see my mate who normally sorts me out with everything. This is what he advised
Pioneer PDP 435XDE (which we really liked over the Panny)
He said that the Pioneer DVR-920H was good but too overpriced just to get HDMI feature, (please some one tell me what differnece this feature) makes and suggested getting Pioneer DVR-720H-S & spend the money on better component cabling. He said to go for Pioneer VSX-D814-S receiver or if still available the Pioneer VSXD-912 which although older is better spec than the 814.
I am getting mixed reports regarding loss of quality using a DVD recorder for playback. The general concensus is to have a stand alone DVD player as well. I still have my old Pioneer DV530 would that be good enough or do I really need another one like the DV-470-S or does it need to be better
Than as far as speakers are concerned because I want small speakersand having been put off the Bose, he suggested going for the Pioneer S-VLF5 or S-VLF3. But having spoeken to someone else they suggested the Infinity Oreus. I didnt get a chance to listen to them but they said they didnt rate the Bose and that these were much better if I was looking for small speakers. As the subwoofer has has a 100 watt amp would I still need the receiver.
I'll still be running Sky as well.
Any more advice greatly appreciated.
I wouldn't think the 814 is worse speck than the 814, better looking yes, worse speck no.
The Yamaha rxv 650
http://www.hiwayhifi.com/site/product.asp?section=&1&Cat=39&Sub=237&Prod=22328
Denon 1705
http://www.tottenhamcourtroaddirect.co.uk/scripts/prodView.asp?idproduct=181
Denon 1905
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/1962
What home cinema rated the 1705 over the rxv650 and the Pioneer 814.
The Canton cd1 are also worth looking into
http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=8052&source=PriceRunner
Sorry which do you mean u put the same model number twice
Sorry blonde moment there :eek: the 814 wont be a worse speck then the 912. The 814 also has dolby PL2x over the 912 otherwise is the same speck.
Sony DB790 (6.1) or DB795 (7.1) are also great amps on this pricerange. We (in Finland) order these from Germany, because they have got Pan-European guarantee.
These Sonys are cheaper than the 814, and also bit more powerful and "heavier". They are big though.. All from the same brand -thinking is healthy, and aesthetically you can't beat it. But remember that speakers are a different world, and Pioneer, Pana or Sony don't really excel there. :rolleyes:
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
