What rear centre for Mission FS1AV?
Discussion in 'Home Cinema Speakers' started by tpugs, Aug 18, 2003.
  1. tpugs
    tpugs
    My Mission FS1 AV came as a 5.1 package, but I want to upgrade to 6.1 ... so I guess that just means wiring in a single rear center speaker, directly the reciever.
    She who must be obeyed demands a matching speaker, so that means another Mission FS1.
    But I cannot work out whether this should be a Centre speaker (as per the front centre) or an identical unit to the rear speakers.
    Any answers gratefully received.
  2. luv ya jen
    luv ya jen
    i have the same speakers QUESTION where are you gonna run the rear center from????
  3. tpugs
    tpugs
    Hi...I'm getting a Sony STRDB2000, which has an output for the 6 bit (IE additional center).
    I'm a bit wary...as it'll be the only one not driven out of the Sub.
  4. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    If it was me I would just buy another FS1 speaker which can be bought on their own from :- http://www.hifistore.co.uk/product.php?qsProd=FS1PANEL they also list a centre one http://www.hifistore.co.uk/product.php?qsProd=FS1CENTRE so maybe centre and rear speakers are different ?!?
    If only I could get a FS2 single speaker for a 6.1 setup, Might just buy a FS1 speaker. Audio wise you should really buy a FS1 speaker as it matches acoustically with the other NTX flat panel speakers.
    Not sure on the FS1 but all the FS2 speakers are the same so does not matter which one is used for front, rear or centre or centre rear.
  5. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    if u get a FS1 for the rear centre, it is of utmost importance u set the Sonys setting to 'small' otherwise the NXT panel will fry, as its trying to deliver bass which it can't.
    good luck anyway
  6. FazerThou
    FazerThou
    Aug 23, 2003
    1,816
    Bath
    +138
    This reply is probably too late but i'll try anyway
    When i had the fs2 system i did the same and went to 6.1 but instead of buying a rear surround i bought a dedicated center speaker and used the fs2 center at the back.
    Just run the amp center to center spk and the rear center to the center input on the sub
    Definatley made a differnce having better center speaker
  7. tpugs
    tpugs
    Not too late as I'm still waiting for the Sony Db2000 to become available.
    I had'nt thought about switching the Center - good call.
  8. luv ya jen
    luv ya jen
    any ideas where i can get longer rear speaker wire for the mission fs1
  9. FazerThou
    FazerThou
    Aug 23, 2003
    1,816
    Bath
    +138
    cant u get it from mission?
  10. tpugs
    tpugs
    I saw on another thread that the VERY NICE PEOPLE at Mission will give you a convertor that allows you to use your own (better quality) cable and connect into the 'odd' Mission sockets...if you ask very nicely.
    They also mention that given the dynamics of NXT technology, there is no need to buy top quality cabling. I'm not sure if this is a reflection on the audio quality of FS1's or the simply the demands made upon the cables by NXT.
    As an aside, LuvYaJen, I'm tired of waiting for Sony to launch the DB2000, can you let me know what you think of the Pioneer 912 running FS1AV's - it looks like a mighty fine reciever, but what's it sound like?
  11. luv ya jen
    luv ya jen
    should be getting mine mon tues from techtronics check out what video website for a full review
  12. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    A question
    Do the speaker wires connect to the sub or to the amp on the FS1 system?
  13. luv ya jen
    luv ya jen
    from the amp to the sub to the speakers
  14. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    had my amp for a couple of months now and im over the moon with it handels anything i throw at it pod scene sounds amazing blade 2 is sssssooooooooo cool (audio wise) stereo is spot on everything about it is brilliant...........tpugs did you get a rear centre if so how does it sound im after getting one myself did you get a surround or a centre please let me know as im should be getting one soon
  15. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    If I were you I would put the whole lot in the bin. The FS anything package is a pile of pants. Try again.
  16. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    have you ever heard the fs1 speakers sweaty sock
