What quality is VHS cassette for audio?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Vipen, Aug 2, 2002.
  1. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    i want to record from my satellite receiver but it hasn't got any outs other than scart. so wondered if i could record onto VHS cassette (longer recording too) and then find a way of getting it onto cd from there.
    I think i remember being in a studio years ago where they used video cassettes for recording their sessions.
    any ideas?
    btw, i can't get this station on traditional radio where i live.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    HiFi sound isn't bad BUT most new decks have auto level only
    The vcrs in recording studio - did it look like this ?
    http://homepage.ntlworld.com/hamidk/sonyslf1.htm
    There was a PCMF1 adaptor which was used to record at CD quality on a Beta tape.
    So for now just make sure you have manual level control!
  3. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    well it looked similar but can't honestly remember. sure it was normal video recorder. it was a long time ago.
    have to give it a go and see the results tonight.
    cheers
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    I tape loads of stuff off my Nicam VCR Vipen onto Minidisc, via 2 phono leads from my VCR (it has audio outputs) all I have to do is set the analogue recording level to the correct level. I dont think recording to a CD-R hifi deck should be any different. But you will need to use a Nicam VCR to get 44.1 sound quality.
    HTHs
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    You only need NICAM for recording off analogue terrestrial, any HiFi stereo VCR will do for recording off a sat box!
    I record off DTTV using an old Ondigital box and a Sanyo HiFi vcr with a mono PAL tuner - it works fine!
  6. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    326
    +25
    I have used an old Akai Hi fi video recorder for past 5 years for recording Bob Harris and other shows from radio. It has manual gain and phono inputs and outputs, and sounds excellent with no hiss that you get with cassettes. I would look around for an old model and get video head changed if needed.
