What qualify's as a High Definition TV
Discussion in 'General TV Discussions Forum' started by Ash007, Sep 21, 2004.
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    What qualify's as a High Definition TV. I was thinking of getting a Sony KE-42MR1 plasma screen. It doesn't specify hdtv although it does have component inputs and 1024x768 Pixels. Can all Plasma's take hdtv as they usually have at least 1024x768 Pixels?
    Ash
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Ash,
    HDTV resolutions are defined as 720p, 1080i and 1080p - the Sony should be able to accept 720p and 1080i at least. Most plasmas should accept HDTV signals, which would then be scaled to fit the panel's native resolution. Hope this helps.
    Steve
  3. beeblebrox12
    beeblebrox12
    My personal advice: if you are informed enough to ask this question, this plasma ain't for you. Buy a real HDTV set - i.e at least 1280x720 native resolution.
  4. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    I can get this Plasma for a bargain price. Is it still not worth gettin for £1500. Half the usual price. Is HDTV going to happen soon, or could it be years away. Won't this tv still work with HDTV anyway?
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,215
    +3,068
    I would suggest that before actually purchasing the thing you confirm with Sony that it will accept and display the current resolutions and refresh rates for HD as well as those we may get here, ie [email protected]@50Hz and also that it will do so using the signal format you want to use....ie RGBHV, YPrPb, DVI, HDMI..... Just because it has lots of pixels doesn't mean to say it will.
    Gordon
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Very sound advice, there are going to be a lot of :censored: off people who think their sets will show HD when Sky start squirting it out. Best ask very direct questions now of the manufacturer in writing (e-mail) preferably.....
  7. G Canavan
    G Canavan
    Jan 8, 2004
    176
    Jarrow Tyne and Wear
    Still £1500 quid for a plasma isn't to be sniffed at, by the time HDTV becomes the norm you can just upgrade.
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I'd ask why it is £1500..........There will be a catch....... :lesson:
