What pwer amp for £1000 - £1200
Discussion in 'AV Receivers & Amplifiers' started by Brad_Porter, Mar 31, 2003.
  1. Brad_Porter
    Brad_Porter
    Right,
    Maybe I should ask my last threads question this way really.
    I want to upgrade my power section (for the time being) of my system and I only have a budget of around £1000-£1200 to cover my 5 M&K speakers. Please bear in mind that my speakers are all 4Ohms and will need a fairly decent amp to cope!!
    I know its not a vast amount of money for a power amp, but if it was your £1200, where would you place it. Once again, bear in mind that the amp has to have good current delivery as these are all 4Ohm speakers; I like to play my system fairly loud (especially while demoing) so it neads headroom.
    Is it possible for this kind of money? It has to exceed an Arcam P-25 3 Channel Power Amp otherwise its not worth me spending the money to upgrade for more slam!
    Regards,
    Brad Porter
  2. nathan_silly
    nathan_silly
    2nd hand.
    Rotel 991 and 993, 200w per channel, THX. Should be able to get them for about £250 each.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Erm ... £250 for a 991 would be a bargain, £250 for a 993 would be a miracle ... usual price for them are around £300 and £400 respectively.
    For that sort of money ... take a look at the RMB1095 ... should be around that price new (can't remember exact price).
    Vikki
  4. nathan_silly
    nathan_silly
    Mate bought them at that price! :D
    Three 993's were sold on these forums for £750.
    1095 is £1800 I think
  5. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    I should have said then ... the ones I've seen recently (except the 3 sold here ... but they were a real big bargain) go for a lot more the £250 especially for the 3 channel ones. Recently on the TAG MacLaren classified a 991 went for £300.
    If you can get some cheep, then the RB991 / 993 will do you good, but otherwise I think you may have to look at spending a little more.
    If you already have a Arcam 3ch ... have you considered adding a second one and bi-amping your speakers for more control??
    I think you've already had lots of replies on your other thread though!!
    Vikki
  6. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,096
    3
    +7,973
    I am using a Rotel 1075 THX 5 Ch amp (£800) with five M&K 4 ohm loads. This is a real bargain of an amp with plenty of muscle to drive the M&Ks with ease, never even getting near warm. (room 13ft x 14ft x 12.5ft)
