What PS2 games support Prog scan?
Discussion in 'Playstation Forums' started by jtorry, Dec 22, 2002.
  1. jtorry
    jtorry
    Nov 8, 2001
    523
    I know that the getaway and Teken 4 have prog scan support, are they the only ones? I remember reading that Burnout 2 supports it, but can't find any info on it. So is it just the two games that support prog scan? Thanks.
  2. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    has a prog scan option but not a widescreen one!
    Great game as I'm a big Jango/Boba Fett fan, but some bits are bloody long and when you've used up your 5 continues it's back to the start of the whole level, some of which take well over 30 minutes to complete...
    BTW how do all you prog scan PS2 and X-box guys cope with multiple component inputs to your display?
    Mine is a ceiling mounted front proj and only has one set of component ins, do you swap the sockets around at the player end or is there a box that can support multi component in?s
  3. jtorry
    jtorry
    Nov 8, 2001
    523
    This is my problem. I have Xbox, PS2, Gamecube and DVD player all using component leads, yet I only have once component socket on my tele. I am hoping i will find a nice switch box like i have for scarts, but i don't expect it will be quite as cheap as that was.
  4. NeoBlade
    NeoBlade
    http://www.avforums.com/forums/showthread.php?s=&threadid=56157&highlight=component+switch
    Have a look there at an old post of mine for a Component Switchbox. With a device like this you will be able to have all the component connections you need ^_^
  5. Jamsie
    Jamsie
    Jtorry,
    Burnout 2 Does indeed have Prog-Scan support, and it's a damn fine game to boot!
  6. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    ...and the product is discontinued anway.
    Neoblade, any more details on which switching box you are using?
  7. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    You might want to check out this thread I started about a component video switcher. It isn't cheap, but looks like it will do the business.
    Richard
