Question What projectors support HDR HLG?
Discussion in 'Projectors, Screens & Video Processors' started by BenRyder, May 15, 2018.
  1. BenRyder
    BenRyder
    Dec 9, 2004
    160
    +18
    Hello,
    With Sky Q due to launch HDR soon, the flavour of which I believe is going to be HLG, what projectors support this?
    I currently own an Optoma HD230x which I've had since 2012, but with the bulb running out of hours I'm keen to upgrade to a new 4K HDR projector.
    The UHD550 is within budget and a nice price at the moment on Amazon, but I don't believe it supports HLG. If I'm investing in a new projector I want to get the one that supports the standard that I'll use the most (which I'm guessing will be HLG).
    So.. what projectors support them? How well can the Optoma do faux HDR?
    Many thanks,
    Ben.
  2. paulr2006
    paulr2006
    Jun 30, 2007
    9,513
    Nottinghamshire
    +2,491
    JVC X5900 do :)
  3. DB9S
    DB9S
    Oct 24, 2017
    53
    11
    UK
    +10
    Hi.
    All the current Sony 4K projectors support HLG.
