What projectors should I keep an eye out for on eBay?
Discussion in 'Projectors, Screens & Video Processors' started by ab1385, Dec 18, 2004.
  1. ab1385
    ab1385
    May 30, 2004
    1,279
    Cardiff
    +75
    Well, considering looking at projctors for myself having look at some for my parents for a while!
    Anyway, I really dont have much to spend, so what cheap yet OK 16:9 projectors should I be looking out for on eBay, old models and such? If it's possible, then I'd like to keep it at around £500, and I'd imagine a few upgrades will be going on over christmas!
    What issues with second hand projectors should I be looking at, other than hours on the clock? And also, as a side issue, are many older projectors OK with longer throw distance (~5m)? I looked on projector central at the projection calculator, and only the AE700 seems OK at that distance, which isn't going to come up at £500. :(
    Is there anything worthwhile even vaguely good at this price point second hand (especially with a longer throw distance!)
  2. stevos
    stevos
    May 16, 2004
    5,950
    +536
    To be heavly biased, I am selling a Infocus 4800 on ebay at the moment.
    For £400 (current price) it is a bargin, that will show you what Lord of the Rings battle scenes are really about. :thumbsup:
    It may not be 16:9, but from my experience a 4:3 DLP beats a 16:9 LCD at a similar price.
    I have recently replaced the 4800 and after several months looking, I haven't seen any decent 16:9 projectors for less than £1000 on ebay. Atleast, none that are not scams.
    I have seen the SP4805 (which is a 16:9 projector) at my local dealer, and the difference is very small.
    If I was you, i would save up and buy a Infocus 5700, but they are around £1800.
  3. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    A bit old now, but still a great pj is the Sony VPL-W400 . It was one of the first true 16:9 widescreen projectors made and although not cutting edge anymore, still offers fine resolution, excellent colours and a fine picture. You should find one on eBay for no more than £200.
    Something a bit newer, I have seen the new Toshiba ET1 16:9 LCD projector for an incredible £498.99 at : http://www.dabs.com/uk/productview?quicklinx=3kcf&referrerid=WD
    This usually retails for well over £800 so is definately a bargain and looks gorgeous too!
    Plus of course, it's brand new and carries a full warranty.
  4. gazza166
    gazza166
    Jul 31, 2003
    762
    Plymouth
    +23
    I have also been looking at this - gets some good reviews considering the price. I have also found it slightly cheaper at Ebuyer ( £488 delivered) and Technoworld ( £490 delivered ).
    There's also one on Ebay which ends today at 2145. It's £370 at the moment which I think is a little expensive given the new price, but there are some good photos of it. Looks very nice.
    Anyone have any views/knowledge of the Toshiba ?
