What projector for a shiny cafe?
Discussion in 'Projectors, Screens & Video Processors' started by ermis, Jun 3, 2004.
  1. ermis
    ermis
    The cafe is open day and night. I need to install a projector for EURO & Olympics.
    The projector is going to be installed indoor but the lighting environment is quite shiny.
    Front projection; distance 7-8 meters; diagonal 4-5 meters
    Should I go for DLP or LCD?
    How many lumens minimum?
    What other specs should I look for (ie contrast)?
    Thanx in advance
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    DEFINITELY not DLP..... you run a far too large risk that a section of viewers find it damned annoying as far as rainbows! You should thus go for LCD and shouldnt be looking for a cinema projector, rather a data one, probably with 2000 lumens+. Pretty much everything else is irrelevant for your use
    ad
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Ad,
    I don't think DLP would be a problem for this application as all the sport will be daylight or high level floodlights so you won't have a the normal scenario where people see rainbows ie very dark areas with bright highlights.
    But yes a PJ with plenty of ansi.
    Jeff
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Ad,
    Jeff
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Jeff, I guess you are right, but even given that, DLP tends to be dimmer than LCD's.... I can think of very few 2000 ansi lumens DLP's.... in fact i cant think of any...
    ad
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    How about NEC LT260K (2400 ansi)
    Or HP XP8010 (2600 ansi )
    Or Toshiba TDP-D2 (2500 ansi )
    Jeff :rtfm:
