What Projector do People use with a DVD32R with PSM?
Discussion in 'TAG McLaren Audio Owners' Forum' started by Londonrich, Sep 12, 2004.
  1. Londonrich
    Londonrich
    My current projector just died and since it is 7 years old time for an upgrade rather than repair.
    I have a Tag DP and DVD32 R with PSM - and I wondered what people recommend as a good combination. I have always liked the look of the SIM300 and wondered if anyone had that and had any comments and what other ones people would recommend.
    Also having the PSM module - should I avoid unit such as the SIM with a build in scaller or is it not a problem.
    Thanks for your comments.
    Richard
  2. kallenby
    kallenby
    I demo'd quite a few & chose the NEC HT1100 for price / performance.
    Hooked up via DVI, the picture is great on DVD to my 120" screen.
    TV varies depending on the quality of input but i'd guess that in the UK, this won't be a problem. Over here, it varies enormously - especially for US TV feeds but the football looks great which is the main thing ! :thumbsup:
  3. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Always get a demo using your source kit, apart from that pearl of wisdom its all down to money.......
