N
nathan_silly
Say I've got Kef Q55 fronts, Kef Model 100 centre, Kef Q15 rears, Kef dipole sides, Rel Stentor sub.
Now for AV use it'll sound best everything set to small, 80hz crossover, subwoofer set to 80hz.
But for music you might want the Kef Q55's set a bit lower, say 40hz, with the subwoofer set to 40hz.
What processor can do this with 7 channel sound?- two seperate speaker size settings depending on the input stream?
The Lexicons can- sort of- if your standard speaker setting is large to all, and you press THX it changes to small 80hz all round. But it only works in 5.1 mode (no Logic 7 expansion)
