What plugs for QED Silver Micro?
Discussion in 'Cables & Switches' started by ajf, Jun 28, 2005.
  1. ajf
    ajf
    Sep 20, 2004
    96
    Just bought some QED Silver Micro to wire up my rear speakers.
    Just wondering what type of plugs will fit on them as the cable is so thin.
    Will normal screw type banana plugs tighten onto the cable enough?
    They need to be self installable.
    Andrew
  2. xivieri
    xivieri
    You need QED airlock plugs for best performance.
  3. bobbypunk
    bobbypunk
    but most will fit, if you don't want to pay £5 each for airloc £10 for 4 Ixos 204 fit fine, others may also be fine but i've not tried anything else with that cable.
