what plsama do i get for 1500??
Discussion in 'Plasma TVs Forum' started by 4bp, Aug 19, 2005.
  1. 4bp
    4bp
    Aug 19, 2005
    71
    hi
    i have just stumbled upon this site and am finding it a superb place to get info on plasmas. i have never owned a plasma and want to buy my first one.
    i have about 1500 to spend and looking to get a 37" (or 42") with a table top stand. i dont mind what make i get. i would idealy like (if possible) to get 5.1 surround sound aswell. i will be hooking up my ps2 and sky+ and dvd player.
    i have found the Samsung PS42V4SX 42" Plasma TV with 5.1 and a glass stand for £1326. is this model any good?
    what should i get??? someone please give me advice!!!!! :lease:
    thanks in advance for your help
    dan
  2. tjradiohead
    tjradiohead
    Jul 29, 2005
    3,895
    71
    +58
    That screen isnt HDTV compatible if that matters to you?
  3. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    Do you have SKY or Freeview. If So get a Panasonic TH37PW7 £1000 from richer sounds with 3 year warranty. add £125 for a RGB to VGA converter.Table top mounts can be had on Ebay for around £50. and a halfway decent All in one Home cinema suround system can be had for around £150.
  4. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    Do you have SKY or Freeview. If So get a Panasonic TH37PW7 £1000 from richer sounds with 3 year warranty. add £125 for a RGB to VGA converter and £40 for a Scart switch box.Table top mounts can be had on Ebay for around £50. and a halfway decent Home cinema suround system can be had for around £150. Most furniture shops do AV stands from around £75. Just within your budget for a dam good screen.
  5. 4bp
    4bp
    Aug 19, 2005
    71
    i will getting sky +. does thismake a differnecE?
    would that be all i need to get?
  6. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    This is all you will need the PW7 does not have a tuner so if you have sky/freeview you will not need one. Please note that this screen is not HD ready, but as HD is in reality a good few years off i would not wory and in my opinion a good SD screen (the pw7 is one of the best) displays SD pictures better than HD screens.
  7. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    its all well and good saying HD is a few yrs off but if you can by a screen now that will handle HD it will save you buying another screen in the near future, but if your not interested in HD then a SD panel like the one mentioned will do you just fine.
  8. paolo999
    paolo999
    Sky HD starts in February.
    If you want HD you can pick up a Hitachi 42" PD5200H for about £1500, currently offered with a free portable DVD player too. Not as good contrast as the standard defintion PW7 (i.e. not as good blacks).
    Stretch another £500 and you can have an HD panasonic with the great contrast they are known for.
  9. neilmcl
    neilmcl
    Oct 29, 2004
    6,224
    103
    Nottingham
    +289
    Where did you get this from? I wasn't aware that an official announcement had been made as yet.
  10. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    SKY are starting a limited HD service early next year, but it wont be another 3 to 4 years before it a a mainstream service, and with the impending format war over HD discs i think it is a better desision to buy a good SD screen as their will be only SD material available for the forseable future. Why spend around £500 more for fetures that you can not use. Espescialy as SD material will look no better and in many cases a lot worse on a HD screen due to upscaling.
  11. 4bp
    4bp
    Aug 19, 2005
    71
    thanks for all the help.
    if i decide to go for a non hd tv, what is the best one with an inbuilt tuner? or is the pw7 the best?
    i am now so unsure whether to invest in an hdtv or not!!!
  12. mikeoxsmall
    mikeoxsmall
    Aug 7, 2005
    89
    i have the samsung ps42v4sx ,and feed it a good signal and the picture is great, buy that and wait for true high definition tv's to come out next year(that is what i am going to do) these so called hdtv's are not high definition at all, they lack the pixels to broadcast hdtv properly, i have seen high definition here in sweden on a pioneer set, and the picture was not as good as would imagine, buy the samsung, you get them for about £1100 on e-bay including the stand, now that is a bargain
