what player??
Discussion in 'Blu-ray & DVD Players & Recorders' started by fakebeard, Nov 30, 2001.
  1. fakebeard
    fakebeard
    hi all :D
    please can you help me....i am looking for a specific player and am not to sure what my options are.
    i need something to output ntsc as ntsc and i dont need progressive scan for loewe reasons.
    i dont want dolby proccesing as the amp is quite good at that.
    i would like a manual region select. the mission if you wish to accept come with a budget of £500 but i would like it closer to £300....i like pioneer but am open to any suggestions.
    many thanks
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,602
    7
    167
    Birmingham, UK
    +10,466
    Can anyone help this chap?
  3. laurel
    laurel
    Try the Toshiba SD210E. circa £170 (www.empiredirect.co.uk).
    I've had this now for 5 months, no probs - has DD/DTS, plays VCD/SVCD on CDR/CDRW and also has MP3 playback.
    I use for movies (obviously!) and am in the process of transferring my old back catalog of VHS to VCD.
    It's not multi-region out of the box, but "mod" can be had for around £40 - well within your budget.
    Cheers matey
  4. fakebeard
    fakebeard
    cheers for the bump i had given up hope a bit.
    as our friend laurel says, the tosh does it all for not much wonga but for some reason i have a dislike for the tosh and i dont know why, maybee it's the price? it is too much player for the money.....where is the catch? also i dont get aroused by the look of the beast.
    the player that does hit the spot is the 737 but i feel it might be overkill. it seems to do everything well so is it worth the extra money and will i even know the difference as this will be my first player?
    i rang for a price at sound and vision but they dont stock it anymore so any ideas as where to get a pocket pleasing price will be greatfully recieved:)
    cheers all
  5. laurel
    laurel
    I know what you mean about the looks of the Tosh :D
    I believe the 737 is quite difficult to obtain now, but how about trying the 646A for about £300 - it's got the look and all the gubbins you need.
    Cheers!
  6. fakebeard
    fakebeard
    how does the picture quality from the 646a compare to the 737?
    thanks again!!
  7. laurel
    laurel
    Unfortunately, I can't give you a review between the two Pioneers, but I did check out the 646 against the 210E.
    I honestly could not choose between the two - and therefore went for the cheaper 210E!
    Now I can't honestly see that the 737 could blow these away in the quality department so I'd say you certainly would not spot the difference.
    Go for it - it's a good machine!
    Hope this helps.
    cHeErS!
  8. encaser
    encaser
    Mar 15, 2001
    2,366
    116
    Suffolk/Essex
    +520
    areadvd.com has a brief review of the 737 (need translate it) and leconcepts.com are getting em in next week @£400.
    This message will self destruct in...:devil:
  9. fakebeard
    fakebeard
    is leconcepts.com a trustworthy company and are they in the uk?
    sounds french ?
    cheers :cool:
    also any other companys in the uk i can get a 737 deal from?
  10. Rathion
    Rathion
    Oct 29, 2001
    Hehe it's not le concepts it L.E Concepts (Leading edge)
