What plasma should i get..
Discussion in 'Plasma TVs Forum' started by droolinggimp, Dec 17, 2004.
  1. droolinggimp
    droolinggimp
    May 26, 2004
    138
    Derby
    Im new to Plasma so please help me out.
    i know theres lots of sort out there but the bottom line is it got to have :
    42 inch screen
    3000+ contrast
    no speakers
    a stand for my table
    be able to plug in my pc so i can use pc on the screen obviously
    component sockets
    2 scart sockets
    i will be using a yamaha rxv 740rds av amp
    i think thats about it.. any help will be much appreciated.
    chris. :)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. viewer
    viewer
    Sep 26, 2004
    91
    Why not HD7
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if budget goes up to £2.5k then add the PHD7 MXE1 (lower contrast) and the NEC XM3???
  5. viewer
    viewer
    Sep 26, 2004
    91
    Horneydragon - how does the Pio MXE1 compare to this Panny PHD7 - which is better.
  6. viewer
    viewer
    Sep 26, 2004
    91
    See Pioneer just launched new 42" pannel - PDP-42MVE1
  7. droolinggimp
    droolinggimp
    May 26, 2004
    138
    Derby
    OK.
    dvd to amp - component
    amp/dvd conection to plasma - component
    ps2 and xbox to plasma - scart
    NTL to plasma - scart
    PC to plasma - what ever the conection is to my lcd monitor for PC like a small 15 pin with a metal line in it too (no idea what its called , sorry)
    Thats is
    Budget? about 2k to 2.2k
    Dont need sound for plasma I repeat NO SOUND FOR PLASMA NO SPEAKERS :D
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK drooling gimp XBOX and PS2 can ouput componet so use that via amp if it has 3 component inputs
    ntl via JS RGB>VGA converter to VGA on panel
    Sounds like DVi for PC
    So choices are Panny Panel PWD6 (black) £1549 AV sales with free input card need to buy DVi card £1700 inc wall/desk mount total + cables & converter
    for VGA/component and DVi inputs Deliverd JAN (limited stock offer)
    Panny PWD7(black or silver) £1860.15 deliverd (black) £1060.15 delivered (silver) both same input and mounts as above
    Again Panny PHD7 1024x768 res panel better for PC USE £2770.60 with same inputs etc as above
    Pioneer MXE1 similar to PHD 7 but more money (I'm a panny expert really not PIO)
    Some food for thought
  9. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    Anyone seen the new Pio PDP-42MVE1? Sounds promising on paper. Looks like it has all the necessary connections that are missing on the pw pannys
  10. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    116
    16
    Horny, yamaha rxv 740rds only has 2 component in m8 :lesson: lol
    You know you love me and my little problem :laugh:
    Regards
    Andy
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    in that case use the one you play most via component or get a component switcher
