What Plasma for a grand???
Discussion in 'Plasma TVs Forum' started by lewisn1, Mar 28, 2006.
  1. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Wish they would have a topic called this on the What Hi-fi mag!!!
    I have at most £1200 to buy a new tele, I think its going to be a plasma becasue the images on the DLP rear-pro still seem worse than the plasmas at this price range.
    Any advice on what models I could look for would be welcome?
    Thanks,
  2. Kevstir
    Kevstir
    Aug 22, 2005
    726
    46
    Falkirk
    +185
    Hi m8
    I your looking for a TV you could pick up an LG 42PX4DV which i believe is HD Compatible , you can get them in your price range from many Online stores , they got very high marks in what plasma mag , theres also a few members on here with them thats eem to be very happy..
    If a panel interests you , you could got for a pw8 from av-sales for £1080 delivered , you would need a seperate tuner( freeview,sky.telewest) and sound system for that though
    Kev
  3. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Thanks Kev, I'll look into review for that LG model.
  4. Kevstir
    Kevstir
    Aug 22, 2005
    726
    46
    Falkirk
    +185
    no probs m8 :smashin: , please note its only HD compatible NOT HD ready
  5. Seek
    Seek
    hi at this price range you have if i was you i would not go plasma i would go for a nice LCD or if you want a big screen DLP is the way with £1200.
    you can get a sagem 45" DLP HD ready for £1200 and the picture on that thing will be better then a £1200 plasma plus it will be future proof.
  6. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Check out the FAQ sticky at the top of the page also, it has lots of ideas on the same question :D
  7. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Thanks all,
    seek, do you know much about the sagem, cos I was looking at that one but people put me off with all the rainbow effect talk and the bulb runs out soon etc thing. I have read about them but i'm still 50/50 between a £1200 plasma and the sagem DLP
    Thanks,
  8. Seek
    Seek
    a close friend of mine has one and he really likes it alot he has not had any problems with rindow effect.
    i have seen it running in SD and HD format it is a nice TV it will be much better than a £1200 plasma that is for sure.
    like you say the down side is the bulbs need replacing after 10000 hours but if you think about it 10000 is a long time away.
    if i only had £1200 and could nto go any higher i would 100% go for the sagem.
    go and test it at the shop there will be £1200 plasma there aswell that will help you make up your mind alot better then reading all people horror storys on the forums remember people do not post on forum much when everythin is running great on the tv they only post when things have gone wrong for help and so on.
    seek
  9. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Panasonic PWD8
  10. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Thanks for the advice seek. Will look more into the Sagem, it looks nice to.
  11. heath
    heath
    Mar 18, 2006
    13
    3
    I'm in a similar situation.
    In Rear Projection forum, the Sony 50" KDFe50A12 gets mostly rave reviews, & is under £1200. Is it better value/quality than Sagem ??
  12. n0chex
    n0chex
    Oct 31, 2003
    7,727
    Here on AVF
    +423
    Better than a Panasonic PW8 ,i don`t think so mate and within his £1200 Budget.
  13. Seek
    Seek
    i was talking HD ready for future proofing.
  14. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    If it were me, I'd want to see them next to each other with HD & SD sources before deciding.
  15. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Suspect it's best to ask that in the RP forum my friend.
  16. Seek
    Seek
    i would like to be future proof tho.
    after 4 months of research i went with a 436xde just to be safe £1000 over the bubget i had, he he :rotfl:
    girlfriend was not happy.
  17. n0chex
    n0chex
    Oct 31, 2003
    7,727
    Here on AVF
    +423
    If you want to see both Panasonic PW8 and the sagam 45" side by side there will be no doubt which will be the winner hands down .
    Also the PW* is future proof " HD Ready " just ad a HDMI Board .
  18. Seek
    Seek
    oh is it HD ready with a HDMI board i did nto know that.
    ok that sounds like looking into.
  19. Kevstir
    Kevstir
    Aug 22, 2005
    726
    46
    Falkirk
    +185
    nope the pwd8 is HD compatible its the phd8 thats HD ready, both need the hdmi boards though
  20. n0chex
    n0chex
    Oct 31, 2003
    7,727
    Here on AVF
    +423
    Myself 2 weeks ago was also in the position of buying a new TV plasma or lcd or DPL i made my decision on the Panasonic PW8 after all the reading in these very forums from what other forum members have said about the pW8 and how good it is and now i own one i will also say go BUY one without hesitation you will never look back its the best £1080 ive ever spent.
  21. n0chex
    n0chex
    Oct 31, 2003
    7,727
    Here on AVF
    +423
    Thanks for the correction HD Compatable :smashin:
  22. HoTTdog
    HoTTdog
    Feb 7, 2006
    190
    Kent
    If you want to hang it on the wall then PWD8 ;)
