What pixel's for PC
Discussion in 'Plasma TVs Forum' started by dreads, Nov 6, 2005.
  1. dreads
    dreads
    Nov 2, 2005
    19
    3
    I am thinking of buying a Plasma for TV, Gaming and PC web broowsing.
    What sort of specs should look for.
    I have a sub 2000quid budget
  2. arby1
    arby1
    Nov 1, 2005
    1,589
    +97
    there's a lot of debate about whether HD is worth the money ocnsidering we don't know yet how everything with Sky is going to pan out- but if you're considering it for pc work- it's a must! set your resolution to 800x600 on your pc and you'll see how bad it is, and think on an 850x450 (or whatever they are) plasma it'll be even worse. Sure=, you can send it a higher res, but then you just lose the detail.
  3. ukdan
    ukdan
    Feb 16, 2005
    1,136
    swindon
    +85
    sounds like the pio mxe1 would be ideal for this situation.
    richer sound do them for about £1400...
  4. dreads
    dreads
    Nov 2, 2005
    19
    3
    So will any HD Plasma be ok and if so what would you recomend???
  5. Jango
    Jango
    I've been considering getting a pe50 over a pv500 for a few days, mainly because of the vga input on the pv500.
    I have a media center box which I have connected to my rubbish 25' panasonic crt via compostive. The pe50 doesn't give me many options for connecting it, it's either composite tv-out on the pc (rubbish), or s-vga tv-out to scart. Both not ideal.
    I have DVI on the pc but the pe50 doesn't have that or a hdmi connector. Therefore I'm pushed towards the pv500 which has all the relevant connections.
    Will wait a couple of months (till new year?) to see if the prices come down. I only want to spend £1200-£1500.. I could be waiting a while.
