What picture setting on JVC widescreen for XBOX
Discussion in 'Xbox Forums' started by James W, Jan 28, 2005.
  1. James W
    James W
    My Xbox is set to widescreen iutput, but cant work out what option to set my TV to.
    There is:
    Regular 4:3
    Panoramic
    Zoom 16:9
    Zoom 14:9
    Full
    I thought full would be right, but the image is a bit stretched on that, however on zoom 16:9 and panoramic there is information missing from both top and bottom.
    What do you set your TV to for widescreen XBOX games, or what would you choose from these.
    I can post up the descriptions given to them in the manual if it's any help/
    James
  2. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Set it to full. That's surely the right option for a widescreen signal. Is there a menu/setting on the TV to fine-tune the picture to make it less stretched?
  3. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,658
    EU
    +753
    Hi, I've got XBox + JVC WS TV.
    I've got it set to 'Auto' which always seems to set to 'Full' for XBox input. This is fine for widescreen Xbox games as they appear in perfect proportion, but with non-WS games (as many are) it stretches the game horizontally to fill the screen.
    I think the only way round it is to set the screen to 'Full' for WS games and 'Regular' for non-WS games. TBH, the stretching doesn't really bother me with games so I just leave it on 'Auto' all the time. If you don't want to use 'Auto' then 'Full' will give the same results.
    RDB :)
  4. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Have you tried different games as some games are 4:3 only, hard to believe i know.
    Also there are two widescreen setting on the xbox, i take it you have tried both.
  5. James W
    James W
    I know some games are 4:3, but so far I've only tried halo 2, which seems to be confirmed as widescreen.
    I did try letterbox and wide on the xbox, bnut that didn't seem to change anything at all
