What Panasonic System?
Discussion in 'Home Cinema Buying & Building' started by nogimmix, Dec 4, 2003.
  1. nogimmix
    nogimmix
    Dec 4, 2003
    2,096
    Kent & Canary Wharf
    +83
    Hi, this is my first post so go easy with me. ;)
    After doing a search and reading certain aspects I've now shortlisted two of the following systems.
    Panasonic SCDT310
    Panasonic SCHT900
    As my budget was really up to £350 I might possibly be able to stretch it a little more. At the moment I can pick up the SCDT310 (multiregion) for £329 from Ritcher Sounds, which seems really good value.
    Just wondering if it's really worth stretching to £400 for the SCHT900 and what would the pro's be?
    I'll be connecting it to my Panasonic TX28PS12, along with SKY TV and a Video.
    Cheers for any help.
  2. blackbull
    blackbull
    I would stretch to the £400 for the 900 Benefits,
    More power
    better looks(uniform integrated speaker stands)
    more flexibilty in terms of format playable on the machine
    I got mine from Techtronic luckily as a multiregion returned model(Box unopened ) for £390 a rbrand new egion 2 model only would be £380 from them excellent value, or to go multi region it would cost £430
  3. Frenchie
    Frenchie
    Depends on your tastes.
    I personally prefer the 310, wooden finish speakers (2 way 'Hi-Fi' front speakers)
