what P4 is it.....
T0rNaDo
Cable Monkey
There are a couple of socket 478 P4's it could be too. The Utility should help but if you have motherboard or make (Dell xxxx) info, that would be useful.
T0rNaDo
its a intel mobo with LGA775 Socket
very basic board..... 2 pci slots.... onboard graphics...
this is the mobo here
prob is it doesnt have any o/s installed.
or i would of tried cpuz ,
guess i could install xp and see.
or i guess other way is to take the hsf off
and see if it states on the top of the cpu.
T0rNaDo
ohh dear slight problem..
i decided to install xp on it to run cpuz to see if that will tell me more info about the cpu.
only prob is its a sata drive,
so i need the sata driver on a floppy
and the intel website doesnt have the drivers i need..
Cable Monkey
Whip off the heatsing and read what is on the processor (if you have the confidence to do it).
Uridium
You shouldn't need the SATA driver unless you are using a RAID array?
PeteD64
Established Member
That's what I thought but someone else on the forums said there is a limit to the size of SATA disk that you can use without special drivers.
I just created a 50GB partition on my disk & installed windows into that.
Cable Monkey
Later boards have the SATA drives mimic extra IDE drives in their bios but older boards needed the additional drivers.
T0rNaDo
sure looks like its going to have to be this way....
i know but the mobo has only 1 ide channel for the dvd rom
and 4 sata channels for hdds.
it has only 1 hdd in the case. a seagate 40gb sata..
Cable Monkey
It should have looked something like this?
RBZ5416
mystic_bertie said:
but does that tell you if its a northwood or prescott ?
If you search the Intel web site for the 5 digit ID you will get the full spec. In this case that's SL7J5.
IIRC, you can ID a Prescott by it's 1Mb cache as opposed to the 512Mb of the Northwood.
AMCross
skt 775 is a prescott only if i'm not mistaken
Cable Monkey
The fact that it is LGA775 tells you straight away it is Prescott except for early Extreme Edition chips. If it is 1Mb then it is not an EE. As stated above!:)
T0rNaDo
well i took the hsf off
and on top of the chip is.....
INTEL PENTIUM 4
2.80ghz/1M/800
SL7KJ
Cable Monkey
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
