What now
Discussion in 'AV Receivers & Amplifiers' started by daren jackson, Jul 10, 2003.
  1. daren jackson
    daren jackson
    I have a Denon 10se (about 3 years old) which is now serving a plasma in the bedroom. The other night both right hand speakers stopped working. Have tested the amp and it seems that both right hand channels of power are not working (all speakers are fine).
    Looking to replace the 10se with either the new 2803 or the 3803. The amp will be used just for TV/Movies.
    Question is will I hear much difference between the two?
    Is the extra £200 difference worth it?
    The speakers I have are 4 x Sonance in ceiling speakers (front/rear Left & Right), my old REL Storm bass and a Boston centre (the smallest decent centre I could find that sits under the plasma).
    Many thanks for any suggestions
