what new Nvidia GFX ? do i need
Discussion in 'PC Gaming & Rigs' started by Jayde, Nov 15, 2004.
  1. Jayde
    Jayde
    hi :)
    whats the best fastest (cheapest if poss) pc gfx card now ?
    what you using ?
    how much ram now plz ?
    has to be nvidia still ?
    i have a nvidia geforce3 64mb Ti 200 but it wont happliy run call of duty addon altho the orig game was ok !
    game runs then crashes.. soon after..
    on a 1.8 ghz Asus A7A266 M/B
    needs more DDR TOO 1 gig from 500mb
  2. locky79
    locky79
    Aug 27, 2004
    530
    +8
    well...
    for a start you need to set your self a min and max budget so you can roughly filter out a bit.
    i cant really suggest any good nvidia cards as im very rusty on that side but i heard the 6800 GT are pretty good.
    ATI card i think you should consider the 9800 pro as they are very cheap at the moment and give excellent performance.
    hope i helped a bit but really set your self a budget and we can help you out a bit more,
    Bleh
  3. Jayde
    Jayde
  4. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +683
    6800LE has a lot of good reports, and goes for about £120 to £150. :)
