DIESELind
Hi there!
First post and it may be a complicated question so I do apologise. I also would like to thank everybody in advance for their input and advice.
I've done a little research and can't find an answer which meets exactly what I want to do. Im quite switched on but no master electrician so if you could keep trade terms and acronyms to a minimum. That would be a great help in simplifying it for me.
I'm looking to install a Quattro LNB onto a Sky minidish and running it to a multiswitch.
From there I want to run feeds to 6 rooms for sky. (I'm not currently putting in 6 boxes. I'm just future proofing because I've bought a house and I'm gutting it. So when all the walls are bare I may as well run everything just in case)
Also, from the main living room Sky+HD I want to run coax to the multiswitch and then distribute that to the other remaining 5 rooms.
I'd also like to run a DAB aerial to the multiswitch and then distribute that to the 6 rooms as well.
I'm looking to put one of these ( http://pages.ebay.com/link/?nav=item.view&alt=web&id=190882896125 ) in each of the six rooms. Running the sky to the sky outputs, the dab to the dab output and the RF2 output via the multiswitch to the TV socket. Could somebody also tell me what the return socket is for please?
Is this all possible with one multiswitch or would I need a separate booster for like this ( http://pages.ebay.com/link/?nav=item.view&alt=web&id=151663770997 ) for the watching of th living room Sky+HD box in the other rooms?
-- As an eBay Associate, AVForums earns from qualifying purchases --
