What make of filter is best?
Discussion in 'Photography Forums' started by jools230575, May 2, 2005.
  1. jools230575
    jools230575
    Hi there
    Would anyone care to recommend a good make of filter? Is this a minefield question?
    Have seen the effects that filters can have on photos and I am keen to experiment :D
  2. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
  3. jools230575
    jools230575
    I've considered B + W filters.
    Looked last night on the web for suppliers in the UK. Tried finding suppliers in the UK but sources seem to be thin on the ground.
    Anyone have a good supplier they use?
  4. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
  5. jools230575
    jools230575
  6. jools230575
    jools230575
  7. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
  8. homerdog
    homerdog
    Mar 7, 2003
    212
    28
    Sussex
    +36
    I guess you're thinking of the Cokin or Lee filter systems.
    Cokin are cheaper, but this starter kit is all you really need for great landscape photography :)
  9. mighty_boosh
    mighty_boosh
    To be honest, I wouldn't bother with filters. It's digital so I'd do it digitally. Why? Well, you will find it harder to remove the effects of a filter on your lens than to add it in Photoshop and you will have more control over the final look. Just my opinion, mind.
  10. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    I spose its a protection thing also but that article i gave a link to has a different idea on that, but there's many who'd disagree with that, it's just one of many view points
    For polarising though i'd use a filter personally
  11. mighty_boosh
    mighty_boosh
    Well I kind of thought that went without saying :D
    Here's a quick example of the flexibility of Photoshop over filters. It's not the most ideal photo (I've had to push the land a bit more than I wanted as it was almost sunset and I was shooting hand-held), but because there is water reflecting the sky I would have needed a ND filter which was top and bottom.
    I took one shot on RAW and output one exposure for sky & water and one for the land and did a quick merge of the two in PS.
  12. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    Thats pretty good mate;)
    I've not got the skills with ps you have not by a long way.
    What do think about the the protection issue of filters?
  13. Johndm
    Johndm
    Jan 25, 2003
    1,813
    Bedford UK
    +56
  14. mighty_boosh
    mighty_boosh
    Thanks Seany.
    Not sure since I read that article you posted. I used to religiously have a skylight filter on all my lenses when I had a film SLR for that very reason and I never noticed any issues with flare. I must admit though, in all my years of photography I've never known anyone to get a damaged front element.
  15. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    I've not got an L lens anymore john have you not read my thead
    I sent the 16-35 back i'm thinking i'm going to hire some lenses or just do what i did with jessops and buy and take back until i find something i'm really really happy with
  16. Johndm
    Johndm
    Jan 25, 2003
    1,813
    Bedford UK
    +56
    just sent you PM
  17. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    I find the lens hood offers my front element more protection than a filter against bangs and crashes... but if i'm off to the coast for the day will tend to plonk on a filter, find SigmaEXs more than acceptable on my Ls.
  18. SnowCat
    SnowCat
    Apr 29, 2005
    39
