Difficult to look past the photoshop series as far as I'm concerned.
If the editing you want to do is fairly limited then Aperture is a fantastic way of importing, converting and manipulating your images, I've used it almost to the exclusion of PS since I got a mac - you would not be able to do things like replace skies with it though so may need something like elements/CS as well.
have a look at http://www.apple.com/aperture/ for a free trial.
There is always Adobe Photoshop Elements (4) for the Mac: £45 or so at PC world possible cheaper in the online marketplace
Presumably the extra £100 for Lightroom is because you get a full workflow management tool rather than an editor?
There is always Adobe Photoshop Elements (4) for the Mac: £45 or so at PC world possibly cheaper in the online marketplace
Possibly....They do seem to lag behindThat's quite tempting. Will Elements 5 be released for mac though?
What about Capture NX?
I use NX for initial post-processing, then use CS2 for what i cant do in NX.
Definitely - NX can be like treacle at times!
