inquisitive
Hello
What is the lowest cost vid-cam that has this spec:
1.[4mm focal length at wide angle (smaller is better)] - edited 7th april to read as the line below.
1.wide view equal or better than focal length of 3.6mm on a 1/4.7 chip
2.manual, optical zoom
3.av out
4.lanc socket
any format is fine
appreciate if anyone has a knowledge of low cost vid-cams that have this spec. thanks for thoughts/knowledge.
stephen
3.av out
4.lanc socket
any format is fine
stephen
