what lnb?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by reevesy, Nov 5, 2005.
  1. reevesy
    reevesy
    Feb 20, 2005
    6,344
    +2,191
    hi,
    can anyone reccommend me a good quad lnb or can you expect the same sort of perfomance/quality across the board?
    cheers.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Not much to choose between them these days.
  3. reevesy
    reevesy
    Feb 20, 2005
    6,344
    +2,191
    righteo then
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,284
    Manchester
    +763
    You need to make sure that it fits in your existing LNB clamp on the dish arm if it's for an existing dish.
    There's very little between them as Nick pointed out , especially for just looking at normal broadcast channels (as opposed to links and feeds).
    The specifications that matter to real "dish-heads" like myself are noise figure, gain , local oscillator stability and phase noise ; however all low to moderate cost LNBs usually specify the above as a "typical" figure only with no maximum or minimum - making the specs pretty useless in reality.
    (couldn't resist that little rant , feel better now).
    Chris Muriel, Manchester.
