what leads
Discussion in 'Plasma TVs Forum' started by davy1100, Jan 25, 2008.
  1. davy1100
    davy1100
    Jan 25, 2008
    47
    11
    :) hi everyone just joined so not sure if this is the right section for this question , i have just got a panny th42px 70 and i want to know what is the besy way to connect my dvd player and sky digital box ie hdmi cables or ordinary scart leads i am new to this so all help and ideas much appreciated and what sort of money should i be spendin on these cables :rolleyes: thanks
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    What make model DVD player?
    What Sky box Standard, +, HD?
  3. Guvna
    Guvna
    Dec 13, 2002
    359
    Swansea
    +21
    Are you using an AV Amplifier/Receiver or going to go direct to the TV?
  4. davy1100
    davy1100
    Jan 25, 2008
    47
    11
    :suicide: sorry folks its a standard sky box and the dvd player is just a cheap one at the minute i was just on the phone with the guy in the shop igot it fron and he said use a hdmi cable for the dvd player and a rgb cable for the sky would this be ok or what else do you think,:) thanks and do these cables all have a standard end fitting for any dvd player sky box etc :rolleyes: and also im goin straight to tv
  5. CalUK
    CalUK
    Nov 18, 2004
    71
    +7
    SCART RGB connection would be the normal connection for a SKY (non HD) box (make sure you set the SKY box to output RGB or you will get a composite output *shudder*). It is an analogue signal so a good quality lead should improve the picture, for simplicity ensure it is a fully wired cable. Personally I use a QED SQART P21 cable, which would set you back about £25 for 1m, that is really the top end of what I would spend on a SCART cable.
    If your DVD player has a HDMI socket then use that, it is a digital connection so lead isn't as important. If it doesn't have one use component (you will need an audio cable as well), if it doesnt have component use SCART RGB as well.
  6. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    If your DVD player is a cheap one you had better double check to see if it has HDMI out, I doubt it. WHY NOT GIVE MAKE AND MODEL it's stops the guess work.
    In the Picture settings on your SKY box set to RGB not Pal and 16:9 not 4:3.
  7. davy1100
    davy1100
    Jan 25, 2008
    47
    11
    :thumbsup:thanks everyone will go and get some cables now cheers
  8. Noggin1980
    Noggin1980
    Aug 2, 2005
    6,821
    +1,175
    If you are going to a high street store don't let them sell you some stupidly overpriced monster cable.
    Personally I'd get your cables online http://www.tvcables.co.uk/ is a good place to start.
  9. davy1100
    davy1100
    Jan 25, 2008
    47
    11
    :)i got a set of philips scart leads from argos for 17 .99seem to to the job :smashin:
  10. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Don't forget to check your Sky box is set in the Settings.Picture to output RGB (not PAL) and 16:9 (not 4:3)
    Number of times I've seen this set wrong is depressing.
  11. davy1100
    davy1100
    Jan 25, 2008
    47
    11
    :thumbsup:choddo cheers mate i done that
