what lead is required to make 360 hi-def?
puppy
my mates got pioneer 506 xde plasma and wants to play hi-def games, what input does it go in and where can he buy a lead and how much?
Sy1441
Component or VGA, the component cable comes with the premium packs. both cables are also available from most game shops.
tinners
There's a switch on the component cable to select HD or SD and you the just set it up in Xbox config screen
