What LCD TV?
M
MARTIN25
can anyone advise me on which LCD TV to buy? i have around £1000 to spend on one, needs to have 3 scarts and be 30-32 inch. I was looking at the Sony 30HR3 and the KLV-L32M1 :)
E
ehr
Apart from 3 SCARTs, what else do you need? for example, will you be using it for PC games? Is the audio output important? With that budget, you can spec your own box so best think about what you really want.
M
MARTIN25
the audio is quite important but obviously not as important as the picture quality. I would be using an Xbox on the TV, not a PC. Usually, i would only buy a Sony but if there is a better LCD TV for around £1000, i would try that. :)
Amazon Fire TV Cube Gen 3 Review: Coming Soon
