What LCD or Plasma ?
Discussion in 'General TV Discussions Forum' started by djerwood, Oct 19, 2005.
  1. djerwood
    djerwood
    I am trying to decide what TV to buy for my new house. I will be connecting a HDMI DVD Player and eventually Sky HD and a xbox 360. After reading forums and reviews I think I have narrowed it down to 3. 2 Plasma's and 1 LCD. Anymore advice you can offer to help me decision would be much appreciated,
    Pioneer PDP-436XDE
    Panasonic TH42PV500CAB
    Sony KDLV40A12 (LCD)
    I realise that the Sony is the smallest but the resolution impressed me.
    What do you think?
  2. Northerner76
    Northerner76
    Sep 11, 2005
    926
    28
    Wells, Somerset
    +26
    If you want to connect a HDMI DVD and Sky HD you might want to consider a TV with two HDMI inputs (or perhaps one HDMI and one DVI and use a VDI to HDMI converter) - currently the Toshiba 37WLT58 offers 2x HDMI and the Philips 37pf9830 offers one HDMI and one DVI (I think). The TV will also need a component input for the Xbox 360.
    I am in a similar boat to you, but I probably wont get Sky HD for a year or so, so my screen will be mainly DVD, normal TV and Xbox 360. I am looking at the following TV's: JVC37DS6 (37 inch LCD), Tosh 37WLT58 (37 inch LCD) and the Samsung LE40M61 (40 inch LCD - not yet out)
    Personally I would steer clear of Plasma, but that is only because I am still wary of screen burn (even though I know the new panels are far less susceptible) and their lifespan (although I know 50,000+ hours equates to years and years of viewing)
    Looking at the TV's you are considering your budget will stretch to the Philips 37PF9830 - If I had £2.5k to spend thats what I would probably get (although the large screen surround does take some getting used to)
    As for the Sony KDLV you mention - head to the LCD forum and you will see avery long thread about this unit - its got its lovers and its haters
    Final point - response time will be an issue for Xbox 360 gaming... the 37 inch version of the Philips has a quoted response of 6ms (but I am not sure if this is grey to grey of soem other measure) - anyway that is pretty darn quick - should result in no smear.
    If the 37 inch TV's aren't big enough there is also a 42 inch version of the philips but you will need deep pockets.
