What lamp does a JVC HD-65DS8DD tv need??
gingerbreadman
Im thinking of buying a JVC HD-65DS8DD TV, but before i buy i want to know which lamp it requires, and if possible can you please send a link for the cheapest priced lamp.
Cheers :thumbsup:
Waidesworld
The majority of the JVCs are using the same lamp. However buying a TV based on the lamp it uses is like buying a car based on the steering wheel. You should purchase based on the overall pros outweighing the cons of the set. So if lamp price is prohibitive then consider LCD.
