What kind of speaker connection is this?
daymouse
My sister want to upgrade the speakers on her hifi and it has connections I've not seen before so wanted to see if anyone knows and what are the option speaker wise
choons
I have not seen this before. Looks like a proprietary connection (Only that system uses it), what is the model name of the current HiFi?
You could cut the cables off the old speakers and connect them to new speakers. This will keep the plugs intact. Check that the new speakers are 8ohms (8Ω symbol on them).
daymouse
The model is Sony Cmt-s20b
Yeah I think that's the best bet.
When you say they are 8ohms does it have to be that or can it be less such as 6ohms? What's the consequences? Thanks.
choons
6ohms is okay but I wouldn't go any lower.
The ohms is the resistance the speaker creates when current is pushed through it. If it is too easy for current to flow though the speaker then the amplifier can get damaged. Think of it like driving your car in first gear for too long, the engine is designed to have a force resisting it.
It will be fine :cool:
daymouse
Great thanks for the advice
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
