What kind of recorder do I need?
Discussion in 'Blu-ray & DVD Players & Recorders' started by BKGupta, Feb 10, 2005.
  1. BKGupta
    BKGupta
    I want to record my camcorder footage onto DVD, but I also want to be able to edit it by adding credits and also add a stills gallery. I have been doing a lot of searching on the net and it seems that set-top HDD/DVD recorders cannot record a stills gallery onto a DVD and its editing ability is limited. Is there a set-top recorder that can cater for my needs?
    If I have to go the PC route, then I have a Dell laptop with 40 GB hard drive and 512 MB RAM and a firewire connection. What external DVD re-writable drive should I get and what software would I need to achieve my goals.
    Any help will be greatly appreciated. :lease:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    No DVD recorder - with or without a HDD - will allow you to produce a stills gallery onto compatible DVDR media. You will need to go down the PC route.
  3. BKGupta
    BKGupta
    Thank you Rasczak. I was afraid that was the answer I was going to get. Do you have any suggestions for what is the best PC External DVD Re-Writer and software necessary for my goals?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    Dedicated External DVD burners can be expensive - can I therefore suggest you consider an enclosure such as this? You can then get a cheap internal drive to fit in it - for which I would recommend the Pioneer A09 or LG 4163. If you have a Firewire (iLink) connection on your laptop you may find an enclosure connected by this would be faster.
    If you do want a dedicated external drive then the LG5160 (which is based on the 4163) is a good choice.
  5. BKGupta
    BKGupta
    Thank you. I will look into those drives.
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    A09 seems a good bet I have an A04 I think or 104 in my PC
