What is wrong with spring clips?
Discussion in 'AV Receivers & Amplifiers' started by Vection, Jun 12, 2003.
  1. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    As the title suggests really. I put my sisters technics midi/sperates thing together for her. It used spring clips on the amp and I found it sounded quite good.:rolleyes:
    Is there a technical reason the're frowned apon?
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    I think it's to do with the size of cable you can fit in them.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    Agree monkeyboy ... can't get very big cable in ... and also they often don't make very positive connection.
    Vikki
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
    It might be down to the contact surface area of the cable. The cable ends are also exposed to air and may oxidise/degrade quicker. The cable used is often fairly cheap and thin with midi systems so the signal being transmitted along it's length may not be as good as more expensive/thicker cable.
  5. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    I take it that its nothing to do with the actual design then. only the poor quality materials associated with them.
  6. hamtaro
    hamtaro
    spring clips are very poor for sqeezing cable in, mind you some binding posts are quite poor also........denon 1802 springs to mind!
  7. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    The post on the back of mine are poor,not a patch on the ones used on my old 930.
